ONTAP commands
system switch ethernet log show
Display Ethernet switch log information.
The system switch ethernet log show command displays the status and requests for Ethernet switch logs.
{ [-fields <fieldname>,…​]
| [-instance ] }
Specifies an instance of the Ethernet switch devices log status.
[-device <text>] - Switch Name
Specifies the name of the Ethernet switch device to display log status on.
[-log-request {true|false}] - Requested Log
Specifies the state of the log request for an Ethernet switch device. Values: true, false.
[-log-status <text>] - Log Status
Specifies the status of the log request for an Ethernet switch device.
[-log-timestamp <MM/DD/YYYY HH:MM:SS>] - Log Timestamp
Specifies the completion timestamp of the log request for an Ethernet switch device.
[-idx <integer>] - Index
Specifies the index of the Ethernet switch device.
[-filename <text>] - Filename
Specifies the full filename of the Ethernet switch log.
[-filenode <text>] - File Node
Specifies the name of the controller on which the Ethernet switch log resides.
cluster1::> system switch ethernet log show
Log Collection Enabled: true
Index Switch                               Log Timestamp        Status
         1 switch-name01(Switch---SN)           -                    -
         2 switch-name02(Switch---SN)           -                    -
Displays the Ethernet switches, their last log timestamp, and the status of the last log request.
