volume move start
PDF of this doc site
Creating your file...
Start moving a volume from one aggregate to another aggregate
The volume move start
command moves a flexible volume from one storage aggregate to another. The destination aggregate can be located on the same node as the original aggregate or on a different node. The move occurs within the context of the same Vserver.
-vserver <vserver name>
- Vserver Name-
This specifies the Vserver on which the volume is located.
-volume <volume name>
- Volume Name-
This specifies the volume that will be moved.
-destination-aggregate <aggregate name>
- Destination Aggregate-
This specifies the aggregate to which the volume will be moved.
[-cutover-window <integer>]
- Cutover time window in seconds (privilege: advanced)-
This specifies the time interval to completely cutover operations from the original volume to the moved volume. The default value is 30 seconds. The range for valid input is from 30 to 300 seconds, inclusive.
[-cutover-action {abort_on_failure|defer_on_failure|force|wait|retry_on_failure}]
- Action for Cutover (privilege: advanced)-
Specifies the action to be taken for cutover. If the effective cluster version is Data ONTAP 8.3 and later, the default is
retry_on_failure
; otherwise the default isdefer_on_failure
. If theabort_on_failure
action is specified, the job tries to cutover until cutover attempts are exhausted. If it fails to cutover, it cleans up and ends the operation. If thedefer_on_failure
action is specified, the job tries to cutover until the cutover attempts are exhausted. If it fails to cutover, it moves into the "cutover deferred" state. The volume move job waits to issue a volume move trigger-cutover command to restart the cutover process. If theforce
action is specified, the job tries to cutover until the cutover attempts are exhausted and forces the cutover at the expense of disrupting the clients. If thewait
action is specified, when the job hits the decision point, it does not go into cutover automatically, instead it waits to issue a volume move trigger-cutover command as the signal to try the cutover. Once cutover is manually triggered, the cutover action changes todefer_on_failure
. If theretry_on_failure
action is specified, the job retries to cutover indefinitely and it never enters a "hard-deferred" state. After exhausting cutover attempts, the move job waits one hour before trying to cutover again. Issue a volume move trigger-cutover command at any time to restart the cutover process. [-perform-validation-only <true>]
- Performs validation checks only-
This is a boolean option allowing to perform pre-move validation checks for the intended volume. When set to
true
, the command only performs the checks without creating a move job. The default value isfalse
. [-foreground {true|false}]
- Foreground Process-
This specifies whether the volume move operation runs as a foreground process. The default setting is
false
(that is, the operation runs in the background). Note that using this parameter will not affect how long it takes for the operation to complete. [-encrypt-destination {true|false}]
- Encrypt Destination Volume-
This specifies whether the move operation should result in creating an encrypted volume on the destination aggregate. When this option is set to
true
, the destination volume will be encrypted. When it is set tofalse
, the destination volume will be a plain-text volume. When this parameter is not specified, then destination will be same as the source type. [-generate-destination-key {true|false}]
- Generate New Encryption Key for Destination Volume-
This option is specified along with
, a new key will be generated, and that new key will be used for encrypting the destination volume. [-tiering-policy <Tiering Policy>]
- Volume Tiering Policy-
This optional parameter specifies the tiering policy to apply to the destination volume. Tiering policies decide whether the user data blocks of a volume in a FabricPool will be tiered to the cloud tier when they become cold. FabricPool combines Flash (performance tier) with an object store (cloud tier) into a single aggregate. The temperature of a volume block increases if it is accessed frequently and decreases when it is not.
The available tiering policies are:
snapshot-only - Only the volume Snapshot copies not associated with the active file system are tiered to the cloud tier.
auto - Both Snapshot copy data and active file system user data are tiered to the cloud tier.
none - Volume blocks are not tiered to the cloud tier.
all - Both Snapshot copy data and active file system user data are tiered to the cloud tier as soon as possible without waiting for a cooling period.
[-allow-mixed-aggr-types {true|false}]
- Allow Mixing FabricPool and non-FabricPool-
If set to true, moving a FlexGroup constituent from a FabricPool to a non-FabricPool, or vice versa, is allowed. The default value is false. This parameter is only supported for FlexGroup constituents.
[-encrypt-with-aggr-key {true|false}]
- Encrypt Destination Volume with aggr key-
This specifies whether the move operation should result in creating an encrypted volume with aggr key on the destination aggregate. When this option is set to
true
, the destination volume will be encrypted as NAE (NetApp Aggregate Encryption) volume.
The following examples perform a validation-check for a volume named volume_test on a Vserver named vs0 to determine if it can be moved to a destination-aggregate named dest_aggr.
cluster1::> volume move start -vserver vs0 -volume volume_test -destination-aggregate dest_aggr -perform-validation-only true Error: command failed: There is 2.54GB of available space on the aggregate dest_aggr which is not enough to accommodate a volume. cluster1::> volume move start -vserver vs0 -volume volume_test -destination-aggregate dest_aggr -perform-validation-only true Validation succeeded.
The following example performs a volume move start operation to move a volume named volume_test on a Vserver name vs0 to a destination-aggregate named dest_aggr.
cluster1::> volume move start -vserver vs0 -volume volume_test -destination-aggregate dest_aggr [Job 267] Job is queued: Move "volume_test" in Vserver "vs0" to aggregate "dest_aggr". Use the "volume move show -vserver vs0 -volume volume_test" command to view the status of this operation.
The following example performs a volume move start operation to move a plain-text volume named vol1 to an encrypted volume on destination-aggregate aggr1.
cluster1::> volume move start -volume vol1 -destination-aggregate aggr1 -encrypt-destination true [Job 267] Job is queued: Move "vol1" in Vserver "vs1" to aggregate "aggr1". Use the "volume move show -vserver vs1 -volume vol1" command to view the status of this operation.
