      vserver services access-check authentication show-ontap-admin-unix-creds
Display Data ONTAP admin Unix credentials based on username or user ID
The vserver services access-check authentication show-ontap-admin-unix-creds uses the Vserver's ns-switch configuration to determine and display Data ONTAP administrator's UNIX information.
- [-node {<nodename>|local}]- Node (privilege: advanced)
The name of the node on which the command is executed.
- -vserver <vserver>- Vserver (privilege: advanced)
The name of the Vserver.
- { -unix-user-name <text>- Unix User Name (privilege: advanced)
The UNIX username.
- | -uid <integer>- Unix User ID (privilege: advanced) }
The UID of a UNIX user.
This example shows Data ONTAP administrator's UNIX user's UID, GID, home directory, and login shell for user "root" on Vserver "vs1" for node "node2."
cluster1::vserver services access-check*> authentication show-ontap-admin-unix-creds -vserver vs1 -unix-user-name root -node node2
       User ID: 0
      Group ID: 1
Home Directory: /
   Login Shell: /bin/csh
 PDFs
PDFs
