vserver services access-check authentication show-ontap-admin-unix-creds
Display Data ONTAP admin Unix credentials based on username or user ID
The vserver services access-check authentication show-ontap-admin-unix-creds
uses the Vserver's ns-switch configuration to determine and display Data ONTAP administrator's UNIX information.
[-node {<nodename>|local}]
- Node (privilege: advanced)-
The name of the node on which the command is executed.
-vserver <vserver>
- Vserver (privilege: advanced)-
The name of the Vserver.
-unix-user-name <text>
- Unix User Name (privilege: advanced) -
The UNIX username.
-uid <integer>
- Unix User ID (privilege: advanced) } -
The UID of a UNIX user.
This example shows Data ONTAP administrator's UNIX user's UID, GID, home directory, and login shell for user "root" on Vserver "vs1" for node "node2."
cluster1::vserver services access-check*> authentication show-ontap-admin-unix-creds -vserver vs1 -unix-user-name root -node node2 User ID: 0 Group ID: 1 Home Directory: / Login Shell: /bin/csh
