storage tape load-balance modify
PDF of this doc site
Creating your file...
Your file is ready
Modify the tape load balance configuration
The storage tape load-balance modify
command modifies the tape load balance setting for a specified node in the cluster.
-node {<nodename>|local}
- Node-
This parameter specifies the node on which the tape load balance setting is to be modified.
[-is-enabled {true|false}]
- Is Tape Load Balance Enabled-
This parameter specifies whether tape load balancing is enabled on the node. The default setting is false.
The following example modifies the tape load balance setting on node1 in the cluster:
cluster1::> storage tape load-balance modify -node node1 -is-enabled true
