system controller replace show
PDF of this doc site
Creating your file...
Your file is ready
Display status of controller replacement
The system controller replace show
command displays overall information about the currently running, or previously run controller replacement operation. The command displays the following information:
Operation Status
Error message
Recommended action
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields.
The following example displays information about automated nondisruptive operation:
cluster1::*> system controller replace show Node Status Error-Action ---------------- ------------------------ ------------------------------------ node1 Paused-for-intervention Follow the instructions given in Step Details node2 None Step Details: -------------------------------------------- Controller replacement operation has been paused for user intervention. Collect the following info from the current node: 1. vserver services name-service dns show 2. service-processor show -node * -instance 3. network port ifgrp show 4. network port vlan show 5. network interface failover-groups show 6. storage array config show -switch switchname 7. storage encryption disk show 2 entries were displayed.
