vserver fpolicy policy scope show
PDF of this doc site
Creating your file...
Display scope
The vserver fpolicy policy scope show
command displays scope information about all FPolicy policies belonging to the Vserver. The command output depends on the parameter or parameters specified with the command. If you do not specify any parameters, the command displays the following information about all FPolicy scopes:
Vserver name
Policy name
The file extensions to include
The file extensions to exclude
You can use the -fields
parameter to specify which fields of information to display about FPolicy scopes. In addition to the fields above, you can display the following fields:
The shares to include
The shares to exclude
The volumes to include
The volumes to exclude
The export policies to include
The export policies to exclude
Whether file extention check on directories is enabled
Whether monitoring of objects with no extension is enabled
You can specify specific parameters to display only information that matches those parameters. For example, to display scope information only about all FPolicy policies where the -file-extensions-to-include
parameter is set to txt, run the command with the -fields
parameter set to policy-name and -file-extensions-to-include
parameter set to txt.
You can specify the -instance
parameter to display scope information for all FPolicy policies in a list format.
[-fields <fieldname>,…]
If you specify the -fields <fieldname>, … parameter, the command only displays the fields that you specify.
[-instance ]
If you specify the -instance parameter, the command displays detailed information about all entries.
[-vserver <Vserver Name>]
- Vserver-
If you specify this parameter, the command displays scope information only about the FPolicy policies for the specified Vserver.
[-policy-name <Policy name>]
- Policy-
If you specify this parameter, the command displays information only about the specified FPolicy policy.
[-shares-to-include <Share name>,…]
- Shares to Include-
If you specify this parameter, the command displays scope information only about the FPolicy policy or policies that use the specified share or shares in the include list.
[-shares-to-exclude <Share name>,…]
- Shares to Exclude-
If you specify this parameter, the command displays scope information only about the FPolicy policy or policies that use the specified share or shares in the exclude list.
[-volumes-to-include <volume name>,…]
- Volumes to Include-
If you specify this parameter, the command displays scope information only about the FPolicy policy or policies that use the specified volume or volumes in the include list.
[-volumes-to-exclude <volume name>,…]
- Volumes to Exclude-
If you specify this parameter, the command displays scope information only about the FPolicy policy or policies that use the specified volume or volumes in the exclude list.
[-export-policies-to-include <FPolicy export policy>,…]
- Export Policies to Include-
If you specify this parameter, the command displays scope information only about the FPolicy policy or policies that use the specified export policy or policies in the include list.
[-export-policies-to-exclude <FPolicy export policy>,…]
- Export Policies to Exclude-
If you specify this parameter, the command displays scope information only about the FPolicy policy or policies that use the specified export policy or policies in the exclude list.
[-file-extensions-to-include <File extension>,…]
- File Extensions to Include-
If you specify this parameter, the command displays scope information only about the FPolicy policy or policies that use the specified file extension or extensions in the include list.
[-file-extensions-to-exclude <File extension>,…]
- File Extensions to Exclude-
If you specify this parameter, the command displays scope information only about the FPolicy policy or policies that use the specified file extension or extensions in exclude list.
[-is-file-extension-check-on-directories-enabled {true|false}]
- Is File Extension Check on Directories Enabled (privilege: advanced)-
If you specify this parameter, the command displays scope information only about the FPolicy policy or policies that use the specified file extension check on directories. If set to true, the command displays information about scopes where file extension checks on directories is enabled. If set to false, the command displays information about scopes where file extension checks on directories is disabled.
[-is-monitoring-of-objects-with-no-extension-enabled {true|false}]
- Is Monitoring of Objects with No Extension Enabled (privilege: advanced)-
If you specify this parameter, the command displays scope information only about the FPolicy policy or policies that use the specified monitoring of objects with no extension setting. If set to true, the command displays information about scope of policy or policies for which monitoring of objects with no extension is enabled.
The following example displays scope information about FPolicy policies.
cluster1::> vserver fpolicy policy scope show Vserver Policy Extensions Extensions Name Name Included Excluded ----------------- ------------------- -------------------- ------------------- Cluster cserver_pol - - vs1.example.com p - - vs1.example.com vs1_pol mp3 - 3 entries were displayed.
