ONTAP commands
volume file async-delete client show
Display the status of async delete of a directory from the client
The volume file async-delete client show command shows the configuration of async delete of a directory on a volume from client applications.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver Name (privilege: advanced)
This specifies the Vserver on which the volume resides.
[-volume <volume name>] - Volume Name (privilege: advanced)
This specifies the name of the volume.
[-is-enabled {true|false}] - Is Client Async Delete Enabled (privilege: advanced)
This specifies whether async delete of a directory from client applications is enabled on the volume.
[-trashbin <text>] - Trashbin Directory Name (privilege: advanced)
This specifies the name of the trashbin directory.
[-inode <integer>] - Trashbin Directory Inode Number (privilege: advanced)
This specifies the inode number of the trashbin directory.
The following example shows the enable status of async directory delete from the client for volume "vol1" hosted in Vserver "vs1".
cluster1::*> volume file async-delete client show -vserver vs1 -volume vol1
