qos adaptive-policy-group rename
PDF of this doc site
Creating your file...
Your file is ready
Rename an adaptive policy group
The qos adaptive-policy-group rename
command changes the name of an existing adaptive policy group.
-policy-group <text>
- Name-
Specifies the existing name of the adaptive policy group that you want to rename.
-new-name <text>
- New adaptive policy group name-
Specifies the new name of the adaptive policy group. Adaptive policy group names must be unique and are restricted to 127 alphanumeric characters including underscores "_" and hyphens "-". Adaptive policy group names must start with an alphanumeric character.
cluster1::> qos adaptive-policy-group rename -policy-group p1 -new-name p1_new
Renames the adaptive policy group from "p1" to "p1_new".
