event filter rename
PDF of this doc site
Creating your file...
Your file is ready
Rename an event filter
The event filter rename
command is used to rename an existing event filter.
There are system-defined event filters provided for your use. The system-defined event filters cannot be modified or deleted.
For more information, see the event filter create comamnd.
-filter-name <text>
- Filter Name-
Use this mandatory parameter to specify the name of the event filter to rename.
-new-filter-name <text>
- New Event Filter Name-
Use this mandatory parameter to specify the new name the event filter should be renamed to.
The following example renames an existing filter named filter1 as emer-wafl-events:
cluster1::> event filter show Filter Rule Rule SNMP Trap Name Posn Type Message Name Severity Type Parameters ----------- ---- -------- ---------------- ------------- --------- ----------- default-trap-events 1 include * EMERGENCY, ALERT * *=* 2 include * * Standard, Built-in *=* 3 exclude * * * *=* filter1 1 include wafl.* EMERGENCY * *=* 2 exclude * * * *=* important-events 1 include * EMERGENCY, ALERT * *=* 2 include callhome.* ERROR * *=* 3 exclude * * * *=* no-info-debug-events 1 include * EMERGENCY, ALERT, ERROR, NOTICE * *=* 2 exclude * * * *=* 10 entries were displayed. cluster1::> event filter rename -filter-name filter1 -new-filter-name emer-wafl-events cluster1::> event filter show Filter Rule Rule SNMP Trap Name Posn Type Message Name Severity Type Parameters ----------- ---- -------- ---------------- ------------- --------- ----------- default-trap-events 1 include * EMERGENCY, ALERT * *=* 2 include * * Standard, Built-in *=* 3 exclude * * * *=* emer-wafl-events 1 include wafl.* EMERGENCY * *=* 2 exclude * * * *=* important-events 1 include * EMERGENCY, ALERT * *=* 2 include callhome.* ERROR * *=* 3 exclude * * * *=* no-info-debug-events 1 include * EMERGENCY, ALERT, ERROR, NOTICE * *=* 2 exclude * * * *=* 10 entries were displayed.
