event filter rename
Rename an event filter
The event filter rename command is used to rename an existing event filter.
There are system-defined event filters provided for your use. The system-defined event filters cannot be modified or deleted.
For more information, see the event filter create command.
-filter-name <text>- Filter Name-
Use this mandatory parameter to specify the name of the event filter to rename.
-new-filter-name <text>- New Event Filter Name-
Use this mandatory parameter to specify the new name the event filter should be renamed to.
The following example renames an existing filter named filter1 as emer-wafl-events:
cluster1::> event filter show
Filter Rule Rule SNMP Trap
Name Posn Type Message Name Severity Type Parameters
default-trap-events
1 include * EMERGENCY, ALERT
2 include * * Standard, Built-in
3 exclude * * * *=*
filter1
1 include wafl.* EMERGENCY * *=*
2 exclude * * * *=*
important-events
2 include callhome.* ERROR * *=*
3 exclude * * * *=*
no-info-debug-events
1 include * EMERGENCY, ALERT, ERROR, NOTICE
2 exclude * * * *=*
10 entries were displayed.
cluster1::> event filter rename -filter-name filter1 -new-filter-name emer-wafl-events
default-trap-events
3 exclude * * * *=*
emer-wafl-events
2 exclude * * * *=*
important-events
3 exclude * * * *=*
2 exclude * * * *=*
