event filter rename
Rename an event filter
The event filter rename command is used to rename an existing event filter.
There are system-defined event filters provided for your use. The system-defined event filters cannot be modified or deleted.
For more information, see the event filter create comamnd.
-filter-name <text>- Filter Name-
Use this mandatory parameter to specify the name of the event filter to rename.
-new-filter-name <text>- New Event Filter Name-
Use this mandatory parameter to specify the new name the event filter should be renamed to.
The following example renames an existing filter named filter1 as emer-wafl-events:
cluster1::> event filter show
Filter Name Rule Rule Message Name SNMP Trap Type Severity
Position Type
default-trap-events
1 include * * EMERGENCY, ALERT
2 include * Standard, Built-in
3 exclude * * *
filter1
1 include wafl.* * EMERGENCY
2 exclude * * *
important-events
2 include callhome.* * ERROR
3 exclude * * *
no-info-debug-events
1 include * * EMERGENCY, ALERT, ERROR, NOTICE
2 exclude * * *
10 entries were displayed.
cluster1::> event filter rename -filter-name filter1 -new-filter-name emer-wafl-events
Position Type
default-trap-events
3 exclude * * *
emer-wafl-events
2 exclude * * *
important-events
3 exclude * * *
2 exclude * * *
