event filter rename
Rename an event filter
The event filter rename command is used to rename an existing event filter.
There are system-defined event filters provided for your use. The system-defined event filters cannot be modified or deleted.
For more information, see the event filter create comamnd.
-filter-name <text> - Filter Name
Use this mandatory parameter to specify the name of the event filter to rename.
-new-filter-name <text> - New Event Filter Name
Use this mandatory parameter to specify the new name the event filter should be renamed to.
The following example renames an existing filter named filter1 as emer-wafl-events:
cluster1::> event filter show
Filter Name Rule     Rule      Message Name           SNMP Trap Type  Severity
            Position Type
default-trap-events
            1        include   *                      *               EMERGENCY, ALERT
            2        include   *                      Standard, Built-in
            3        exclude   *                      *               *
filter1
            1        include   wafl.*                 *               EMERGENCY
            2        exclude   *                      *               *
important-events
            2        include   callhome.*             *               ERROR
            3        exclude   *                      *               *
no-info-debug-events
            1        include   *                      *               EMERGENCY, ALERT, ERROR, NOTICE
            2        exclude   *                      *               *
10 entries were displayed.
cluster1::> event filter rename -filter-name filter1 -new-filter-name emer-wafl-events
            Position Type
default-trap-events
            3        exclude   *                      *               *
emer-wafl-events
            2        exclude   *                      *               *
important-events
            3        exclude   *                      *               *
            2        exclude   *                      *               *
