ONTAP commands
event filter rename
Rename an event filter
The event filter rename command is used to rename an existing event filter.
There are system-defined event filters provided for your use. The system-defined event filters cannot be modified or deleted.
For more information, see the event filter create command.
-filter-name <text> - Filter Name
Use this mandatory parameter to specify the name of the event filter to rename.
-new-filter-name <text> - New Event Filter Name
Use this mandatory parameter to specify the new name the event filter should be renamed to.
The following example renames an existing filter named filter1 as emer-wafl-events:
cluster1::> event filter show
Filter      Rule Rule                                    SNMP Trap
Name        Posn Type     Message Name     Severity      Type      Parameters
default-trap-events
            1    include  *                EMERGENCY, ALERT
            2    include  *                *             Standard, Built-in
            3    exclude  *                *             *         *=*
filter1
            1    include  wafl.*           EMERGENCY     *         *=*
            2    exclude  *                *             *         *=*
important-events
            2    include  callhome.*       ERROR         *         *=*
            3    exclude  *                *             *         *=*
no-info-debug-events
            1    include  *                EMERGENCY, ALERT, ERROR, NOTICE
            2    exclude  *                *             *         *=*
10 entries were displayed.
cluster1::> event filter rename -filter-name filter1 -new-filter-name emer-wafl-events
default-trap-events
            3    exclude  *                *             *         *=*
emer-wafl-events
            2    exclude  *                *             *         *=*
important-events
            3    exclude  *                *             *         *=*
            2    exclude  *                *             *         *=*
