Command reference
security multi-admin-verify request veto
Veto a request
The security multi-admin-verify request veto command vetoes the specified request.
-index <integer> - Request Index
This allows the user to specify the index of the request to be vetoed.
The following example vetoes the request with index 1:
cluster1::> security multi-admin-verify request veto -index 1
