Command reference
system limits show
Displays the Maximum volume limit
This command displays the Maximum volumes allowed in a node and maximum allowed size of a volume.
[-fields <fieldname>,…​]
| [-instance ] (privilege: advanced) }
[-node <nodename>] - Node's filer ID (privilege: advanced)
This parameter indicates the node name.
[-max-aggr-size <integer>] - Maximum Aggregate Size in TB (privilege: advanced)
This parameter indicates the Maximum aggregate size in TB
[-max-node-vvols <integer>] - Maximum Number of Volumes (privilege: advanced)
This parameter indicates the Maximum Number of Volumes
[-max-hya-ssd-limit <integer>] - Maximum SSD on a Flash Pool Aggregate (privilege: advanced)
This parameter indicates the Maximum hya ssd limit
[-is-200tb-vvol-size-allowed {true|false}] - Is system allowed to create vvols upto 200TB (privilege: advanced)
This parameter indicates the whether the volume of size 200TB is allowed
[-max-vol-size-old <integer>] - Old Maximum Volume Size in TB (privilege: advanced)
This parameter indicates Maximum Volume Size in TB prior to 9.12.1
[-max-vol-size-published <integer>] - User Visible Maximum Volume Size in TB (privilege: advanced)
This parameter indicates Maximum Volume Size in TB published in customer documentation.
Example shows the output of system limits show
cluster1::> system limits show
            Node           Max_volume_size  Max_volume_count
      node1          300                            500
