system limits show
PDF of this doc site
Creating your file...
Displays the Maximum volume limit
This command displays the Maximum volumes allowed in a node and maximum allowed size of a volume.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node <nodename>]
- Node's filer ID (privilege: advanced)-
This parameter indicates the node name.
[-max-aggr-size <integer>]
- Maximum Aggregate Size in TB (privilege: advanced)-
This parameter indicates the Maximum aggregate size in TB
[-max-vol-size <integer>]
- Maximum Volume Size in TB (privilege: advanced)-
This parameter indicates Maximum Volume Size in TB
[-max-node-vvols <integer>]
- Maximum Number of Volumes (privilege: advanced)-
This parameter indicates the Maximum Number of Volumes
[-max-hya-ssd-limit <integer>]
- Maximum SSD on a Flash Pool Aggregate (privilege: advanced)-
This parameter indicates the Maximum hya ssd limit
[-is-200tb-vvol-size-allowed {true|false}]
- Is system allowed to create vvols upto 200TB (privilege: advanced)-
This parameter indicates the whether the volume of size 200TB is allowed
[-max-vol-size-old <integer>]
- Old Maximum Volume Size in TB (privilege: advanced)-
This parameter indicates Maximum Volume Size in TB prior to 9.12.1
Example shows the output of system limits show
cluster1::> system limits show Node Max_volume_size Max_volume_count ----------- ---------------- ---------------- node1 16 500
