system limits show
Displays the Maximum volume limit
This command displays the Maximum volumes allowed in a node and maximum allowed size of a volume.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node <nodename>]- Node's filer ID (privilege: advanced)-
This parameter indicates the node name.
[-max-aggr-size <integer>]- Maximum Aggregate Size in TB (privilege: advanced)-
This parameter indicates the Maximum aggregate size in TB
[-max-node-vvols <integer>]- Maximum Number of Volumes (privilege: advanced)-
This parameter indicates the Maximum Number of Volumes
[-max-hya-ssd-limit <integer>]- Maximum SSD on a Flash Pool Aggregate (privilege: advanced)-
This parameter indicates the Maximum hya ssd limit
[-is-200tb-vvol-size-allowed {true|false}]- Is system allowed to create vvols upto 200TB (privilege: advanced)-
This parameter indicates the whether the volume of size 200TB is allowed
[-max-vol-size-old <integer>]- Old Maximum Volume Size in TB (privilege: advanced)-
This parameter indicates Maximum Volume Size in TB prior to 9.12.1
[-max-vol-size-published <integer>]- User Visible Maximum Volume Size in TB (privilege: advanced)-
This parameter indicates Maximum Volume Size in TB published in customer documentation.
Example shows the output of system limits show
cluster1::> system limits show
Node Max_volume_size Max_volume_count
node1 300 500
