system limits show
Displays the Maximum volume limit
This command displays the Maximum volumes allowed in a node and maximum allowed size of a volume.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-node <nodename>]- Node's filer ID (privilege: advanced)
This parameter indicates the node name.
- [-max-aggr-size <integer>]- Maximum Aggregate Size in TB (privilege: advanced)
This parameter indicates the Maximum aggregate size in TB
- [-max-node-vvols <integer>]- Maximum Number of Volumes (privilege: advanced)
This parameter indicates the Maximum Number of Volumes
- [-max-hya-ssd-limit <integer>]- Maximum SSD on a Flash Pool Aggregate (privilege: advanced)
This parameter indicates the Maximum hya ssd limit
- [-is-200tb-vvol-size-allowed {true|false}]- Is system allowed to create vvols upto 200TB (privilege: advanced)
This parameter indicates the whether the volume of size 200TB is allowed
- [-max-vol-size-old <integer>]- Old Maximum Volume Size in TB (privilege: advanced)
This parameter indicates Maximum Volume Size in TB prior to 9.12.1
- [-max-vol-size-published <integer>]- User Visible Maximum Volume Size in TB (privilege: advanced)
This parameter indicates Maximum Volume Size in TB published in customer documentation.
Example shows the output of system limits show
cluster1::> system limits show
            Node           Max_volume_size  Max_volume_count
      node1          300                            500
 PDFs
PDFs
