Command reference
volume quota policy rule show
Display the quota rules
This command displays the following information about quota policy rules by default.
  • Vserver name
  • Quota policy name
  • Volume name
  • Type of quota policy rule
  • Target of the quota policy rule
  • Qtree name
  • User mapping
  • Hard disk limit
  • Soft disk limit
  • Hard file limit
  • Soft file limit
  • Threshold for disk limit
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver
If this parameter is specified, the command displays information about quota rules for the quotas contained on volumes on the specified Vserver.
[-policy-name <text>] - Policy Name
If this parameter is specified, the command displays information about quota rules for the specified quota policy.
[-volume <volume name>] - Volume Name
If this parameter is specified, the command displays information about quota rules for the quota policy associated with the specified volume.
[-type {tree|user|group}] - Type
If this parameter is specified, the command displays information about quota rules for the specified quota type.
[-target <text>] - Target
If this parameter is specified, the command displays information about quota rules for the specified target.
[-qtree <qtree name>] - Qtree Name
If this parameter is specified, the command displays information about quota rules for the specified qtree.
[-user-mapping {on|off}] - User Mapping
If this parameter is specified, the command displays information about quota rules having the specified user-mapping value.
[-disk-limit {<size>|-}] - Disk Limit
If this parameter is specified, the command displays information about quota rules having the specified hard disk limit.
[-file-limit {<integer>|-}] - Files Limit
If this parameter is specified, the command displays information about quota rules having the specified hard file limit.
[-threshold {<size>|-}] - Threshold for Disk Limit
If this parameter is specified, the command displays information about quota rules having the specified disk limit threshold.
[-soft-disk-limit {<size>|-}] - Soft Disk Limit
If this parameter is specified, the command displays information about quota rules having the specified soft disk limit.
[-soft-file-limit {<integer>|-}] - Soft Files Limit
If this parameter is specified, the command displays information about quota rules having the specified soft file limit.
The following example displays information about all the quota policy rules in a cluster. There is one user rule that exists on Vserver vs0 for the quota policy named quota_policy_0. This quota policy applies to the user named myuser for qtree named qtree0 on volume vol0.
cluster1::> volume quota policy rule show
Vserver: vs0      Policy: quota_policy_0           Volume: vol0
Soft     Soft
                      User       Disk     Disk   Files    Files
Type   Target  Qtree  Mapping   Limit    Limit   Limit    Limit  Threshold
tree   myuser  qtree0 on         20GB     18GB  100000    80000       16GB
