storage failover hwassist stats show
Display hwassist statistics
The` storage failover hwassist stats show ` command displays statistics about the hardware assist alerts processed by a node. The command displays the following information for each alert:
Locally enabled.
Partner Inactive Reason.
Alert type.
Event that triggered the alert.
The number of times the alert has been received.
Whether takeover was possible on receiving the alert.
The last time at which the alert was received.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
Selects the hwassist statistics for the specified node.
[-enabled {true|false}]- Local Hardware Assist Enabled-
If you specify this parameter, the command displays information only about hwassist statistics on nodes with the specified enabled state.
[-local-inactive <text>]- Local Node's Hwassist Inactive Status Reason-
If you specify this parameter, the command displays information only about hwassist statistics on nodes with the specified inactive reason.
[-power-loss <text>]- Power Loss Alert-
If you specify this parameter, the command displays information only about hwassist statistics on nodes with the specified power-loss event.
[-watchdog-reset <text>]- Watchdog Reset Alert-
If you specify this parameter, the command displays information only about hwassist statistics on nodes with the specified watchdog-reset event.
[-power-off-via-rlm <text>]- Power Off by Using RLM-
If you specify this parameter, the command displays information only about hwassist statistics on nodes with the specified power off event via Remote LAN Manager.
[-power-cycle-via-rlm <text>]- Power Cycle by Using RLM-
If you specify this parameter, the command displays information only about hwassist statistics on nodes with the specified power cycle event via Remote LAN Manager.
[-reset-via-rlm <text>]- System Reset by Using RLM-
If you specify this parameter, the command displays information only about hwassist statistics on nodes with the specified reset event via Remote LAN Manager.
[-power-off-via-sp <text>]- Power Off by Using SP-
If you specify this parameter, the command displays information only about hwassist statistics on nodes with the specified power off event via Service Processor.
[-power-cycle-via-sp <text>]- Power Cycle by Using SP-
If you specify this parameter, the command displays information only about hwassist statistics on nodes with the specified power cycle event via Service Processor.
[-reset-via-sp <text>]- System Reset by Using SP-
If you specify this parameter, the command displays information only about hwassist statistics on nodes with the specified reset event via Service Processor.
[-dimm-uecc-error <text>]- DIMM UECC Fatal Error Detected by Storage OS-
If you specify this parameter, the command displays information only about hwassist statistics on nodes with the specified DIMM error event.
[-post-error <text>]- POST Error Alert-
If you specify this parameter, the command displays information only about hwassist statistics on nodes with the specified post error event.
[-abnormal-reboot <text>]- Abnormal Reboot Alert-
If you specify this parameter, the command displays information only about hwassist statistics on nodes with the specified abnormal reboot event.
[-loss-of-heartbeat <text>]- Loss of Heartbeat Alert-
If you specify this parameter, the command displays information only about hwassist statistics on nodes with the specified loss of heartbeat event.
[-keep-alive <text>]- Periodic Message Alert-
If you specify this parameter, the command displays information only about hwassist statistics on nodes with the specified keep alive event.
[-test <text>]- Test Alert-
If you specify this parameter, the command displays information only about hwassist statistics on nodes with the specified test event.
[-bad-nvram-id <text>]- Bad NVRAM ID Alert-
If you specify this parameter, the command displays information only about hwassist statistics on nodes with the specified bad NVRAM ID event.
[-ss-mismatch <text>]- Shared Secret Key Mismatch Alert-
If you specify this parameter, the command displays information only about hwassist statistics on nodes with the specified shared secret mismatch event.
[-unknown-alerts <text>]- Unknown Alerts-
If you specify this parameter, the command displays information only about hwassist statistics on nodes with the specified unknown alerts event.
[-times-throttled <text>]- Number of Throttled Alerts-
If you specify this parameter, the command displays information only about hwassist statistics on nodes with the specified times throttled event.
The following example displays the hwassist statistics for the node ha1:
cluster1::> storage failover hwassist stats show -node ha1
Node: ha1
Local Enabled: true
Partner Inactive Reason: -
Alert Type Alert Event Count Takeover Last Received
system_down power_loss 0 Yes ---
system_down l2_watchdog_reset 0 Yes ---
system_down power_off_via_rlm 0 Yes ---
system_down power_cycle_via_rlm 0 Yes ---
system_down reset_via_rlm 0 Yes ---
system_down power_off_via_sp 0 Yes ---
system_down power_cycle_via_sp 0 Yes ---
system_down reset_via_sp 0 Yes ---
system_down dimm_uecc_error 0 Yes ---
system_down post_error 0 No ---
system_down abnormal_reboot 0 No ---
system_down loss_of_heartbeat 0 No ---
keep_alive periodic_message 10 No Wed Mar 9 13:41:28 EST 2016
test test 0 No ---
ID_mismatch --- 0 --- ---
Key_mismatch --- 0 --- ---
Unknown --- 0 --- ---
alerts_throttled 0 --- ---
The following example displays the hwassist statistics for the node ha1 where hardware assist hardware is not supported.
Node: ha1
Local Enabled: false
Partner Inactive Reason: HW assist is not supported on partner.
