network test-link run-test
Test link bandwidth
The network test-link run-test command runs a performance test between two nodes. The command requires a source node, Vserver, and destination address.
Before executing the network test-link run-test command, the network test-link start-server command must be run to start a server on the node hosting the destination LIF. After all tests to that node are complete the network test-link stop-server command must be run to stop the server.
The test results are stored non-persistently and can be viewed using the network test-link show command. Results include input parameters, the bandwidth achieved, and the date and time of the test.
-node {<nodename>|local}- Node Name (privilege: advanced)-
Use this parameter to specify the node which initiates the test.
-vserver <vserver>- Vserver (privilege: advanced)-
Use this parameter to specify the Vserver to access the destination LIF. DC (Data Channel) Vserver option is available only in an ONTAP Select or Cloud Volumes ONTAP cluster. It is a special vserver that hosts LIFs that are used to mirror data aggregates to partner node.
-destination <Remote InetAddress>- Destination (privilege: advanced)-
Use this parameter to specify the destination IP address.
[-num-streams <integer>]- Number of Streams (privilege: advanced)-
Use this parameter to specify the number of parallel client TCP streams to run. This option can be used to test link bandwidth with multiple concurrent TCP connections. Valid range is 1-128. If not specified, a single stream is used.
The following example runs a test between the cluster LIFs, including the start and stop of the server side of the test:
cluster1::*> network test-link start-server -node node1
cluster1::*> network test-link run-test -node node2 -vserver Cluster -destination 172.31.112.173
Node: node2
Vserver: Cluster
Destination: 172.31.112.173
Time of Test: 10/24/2025 15:50:07
MB/s: 2766.148355139331
Number of Streams: 1
cluster1::*> network test-link stop-server -node node1
cluster1::*> network test-link show -node node2 -vserver Cluster
Node Vserver Destination Time of Test MB/s Number of Streams
node2 Cluster 172.31.112.173 10/24/2025 15:50:07 2766.148355139331 1
The following example runs a test with 4 parallel TCP streams for higher throughput:
cluster1::*> network test-link run-test -node node2 -vserver Cluster -destination 172.31.112.173 -num-streams 4
Node: node2
Vserver: Cluster
Time of Test: 10/24/2025 16:12:19
MB/s: 10299.11575470279
Number of Streams: 4
cluster1::*> network test-link show -node node2 -vserver Cluster -instance
Node: node2
Vserver: Cluster
