lun import verify stop
Stop the verify for the specified LUN
This command stops the block by block verification of the foreign disk and LUN data.
-vserver <Vserver Name>- Vserver Name (privilege: advanced)-
Specifies the Vserver that contains the LUN you want to stop block by block comparison with the foreign disk.
-path <path>- LUN Path (privilege: advanced)-
Specifies the path of the LUN that you want to stop the block by block comparison. Examples of correct LUN paths:
/vol/vol1/lun1and/vol/vol1/qtree1/lun1
cluster1::> lun import verify stop -vserver vs1 -path /vol/vol2/lun2
Stops the import verify on lun at path /vol/vol2/lun2.
