vserver vscan scanner-pool privileged-users add
Add to the list of privileged users
The vserver vscan scanner-pool privileged-users add command adds one privileged users or list of privileged users to the specified scanner pool.
- -vserver <vserver name>- Vserver
This parameter specifies the name of the Vserver containing the specified scanner pool on which you want to add a privileged user or users.
- -scanner-pool <Scanner pool>- Scanner Pool
This parameter specifies the name of the scanner pool to which you want to add a privileged user or users.
- -privileged-users <Privileged user>,…- List of Privileged Users
This parameter specifies a list of privileged users. A valid form of privileged user-name is "domain-name\user-name" and can be up to 256 characters long. Privileged user-names are stored and treated as case-insensitive strings. Virus scanners must use one of the registered privileged users for connecting to ONTAP for exchanging virus-scanning protocol messages and to access file for scanning, remedying and quarantining operations.
The following example adds a list of privileged users to the specified scanner pool.
cluster1::> vserver vscan scanner-pool privileged-users add -vserver vs1
            -scanner-pool p1 -privileged-users cifs\u2,cifs\u3
cluster1::> vserver vscan scanner-pool privileged-users show -vserver vs1
            -scanner-pool p1
Vserver: vs1
            Scanner Pool: p1
List of Privileged Users: cifs\u1, cifs\u2, cifs\u3
 PDFs
PDFs
