vserver vscan scanner-pool privileged-users add
Add to the list of privileged users
The vserver vscan scanner-pool privileged-users add
command adds one privileged users or list of privileged users to the specified scanner pool.
-vserver <vserver name>
- Vserver-
This parameter specifies the name of the Vserver containing the specified scanner pool on which you want to add a privileged user or users.
-scanner-pool <Scanner pool>
- Scanner Pool-
This parameter specifies the name of the scanner pool to which you want to add a privileged user or users.
-privileged-users <Privileged user>,…
- List of Privileged Users-
This parameter specifies the privileged user or users that you want to add to the specified scanner pool.
The following example adds a list of privileged users to the specified scanner pool.
cluster1::> vserver vscan scanner-pool privileged-users add -vserver vs1 -scanner-pool p1 -privileged-users cifs\u2,cifs\u3 cluster1::> vserver vscan scanner-pool privileged-users show -vserver vs1 -scanner-pool p1 Vserver: vs1 Scanner Pool: p1 List of Privileged Users: cifs\u1, cifs\u2, cifs\u3
