security dynamic-authorization trust-score-component delete
Delete a trust score component
The security dynamic-authorization trust-score-component delete command deletes a custom trust score component. It can be used to delete a custom trust score component that was configured using the security dynamic-authorization trust-score-component create command.
- -vserver <vserver name>- Vserver
This parameter optionally specifies the Vserver associated with the custom trust score component. If not specified, this defaults to the cluster Vserver.
- -component <text>- Component Name
Name of the custom trust score component to be deleted.
The following command deletes a custom trust score component named comp1 for the Administrative Vserver.
cluster1::> security dynamic-authorization trust-score-component delete -component comp1
 PDFs
PDFs
