metrocluster interconnect mirror multipath show
Display multipath information
The metrocluster interconnect mirror multipath show command displays the NVRAM mirror multipath policy for the nodes configured in a MetroCluster.
This command displays the following details about the local node and the HA partner node:
Node: This field specifies the name of the node in the cluster.
Multipath Policy: This field specifies the multipath policy used for NVRAM mirroring.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-node {<nodename>|local}]- Node Name
If this parameter is specified, mirror details of the specified node are displayed.
- [-multipath-policy {no-mp|static-map|dynamic-map|round-robin}]- Multipath Policy
If this parameter is specified, nodes with the specified multipath policy are displayed.
The following example shows the output of the command:
clusA::> metrocluster interconnect mirror multipath show
       Node            Multipath Policy
       clusA-1         static-map
       clusA-2         static-map
 PDFs
PDFs
