ONTAP commands
metrocluster interconnect mirror multipath show
Display multipath information
The metrocluster interconnect mirror multipath show command displays the NVRAM mirror multipath policy for the nodes configured in a MetroCluster.
This command displays the following details about the local node and the HA partner node:
  • Node: This field specifies the name of the node in the cluster.
  • Multipath Policy: This field specifies the multipath policy used for NVRAM mirroring.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node Name
If this parameter is specified, mirror details of the specified node are displayed.
[-multipath-policy {no-mp|static-map|dynamic-map|round-robin}] - Multipath Policy
If this parameter is specified, nodes with the specified multipath policy are displayed.
The following example shows the output of the command:
clusA::> metrocluster interconnect mirror multipath show
       Node            Multipath Policy
       clusA-1         static-map
       clusA-2         static-map
