metrocluster interconnect mirror multipath show
Display multipath information
The metrocluster interconnect mirror multipath show
command displays the NVRAM mirror multipath policy for the nodes configured in a MetroCluster.
This command displays the following details about the local node and the HA partner node:
Node: This field specifies the name of the node in the cluster.
Multipath Policy: This field specifies the multipath policy used for NVRAM mirroring.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node Name-
If this parameter is specified, mirror details of the specified node are displayed.
[-multipath-policy {no-mp|static-map|dynamic-map|round-robin}]
- Multipath Policy-
If this parameter is specified, nodes with the specidifed multipath policy are displayed.
The following example shows the output of the command:
clusA::> metrocluster interconnect mirror multipath show Node Multipath Policy --------------- ----------------- clusA-1 static-map clusA-2 static-map
