metrocluster interconnect mirror multipath show
Display multipath information
The metrocluster interconnect mirror multipath show command displays the NVRAM mirror multipath policy for the nodes configured in a MetroCluster.
This command displays the following details about the local node and the HA partner node:
Node: This field specifies the name of the node in the cluster.
Multipath Policy: This field specifies the multipath policy used for NVRAM mirroring.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node Name-
If this parameter is specified, mirror details of the specified node are displayed.
[-multipath-policy {no-mp|static-map|dynamic-map|round-robin}]- Multipath Policy-
If this parameter is specified, nodes with the specidifed multipath policy are displayed.
The following example shows the output of the command:
clusA::> metrocluster interconnect mirror multipath show
Node Multipath Policy
clusA-1 static-map
clusA-2 static-map
