Command reference
cluster statistics show
Display cluster-wide statistics
The cluster statistics show command displays the following information. Each item lists the current value and; if applicable, the change (delta) from the previous reported value.
  • CPU busy percentage
  • Average of CPU busy percentage (advanced privilege level only)
  • Total number of NFS and CIFS operations
  • Number of NFS operations
  • Number of CIFS operations
  • Number of cache operations (advanced privilege level only)
  • Total amount of network data received (advanced privilege level only)
  • Total amount of network data sent (advanced privilege level only)
  • Number of packets received (advanced privilege level only)
  • Number of packets sent (advanced privilege level only)
  • Busy percentage for the data network
  • Amount of data received on the data network
  • Amount of data sent on the data network
  • Busy percentage for the cluster network
  • Amount of data received on the cluster network
  • Amount of data sent on the cluster network
  • Amount of data read from disk
  • Amount of data written to disk
At the diagnostic privilege level, the command displays the following information:
  • Total number of operations
  • Number of 7M Fcache operations
  • Number of SpinFS operations
  • Total amount of network traffic received
  • Total amount of network traffic sent
  • Percentage of data-network utilization
  • Amount of data-network traffic received
  • Amount of data-network traffic sent
  • Percentage of cluster-network utilization
  • Amount of cluster-network traffic received
  • Amount of cluster-network traffic sent
The following example displays cluster statistics:
cluster1::> cluster statistics show
      Counter         Value         Delta
    CPU Busy:           84%           +27
   Operations:
       Total:     951471448    7210/s:11s
         NFS:   12957951479   13759/s:11s
        CIFS:     342195460     230/s:11s
 Data Network:
        Busy:            0%             -
    Received:        1.98TB  3.18MB/s:11s
        Sent:        6.20TB   903KB/s:11s
Cluster Network:
        Busy:            0%             -
    Received:        6.33TB  1.34MB/s:11s
        Sent:        6.24TB  3.54MB/s:11s
 Storage Disk:
        Read:         207TB  82.7MB/s:11s
       Write:        53.3TB  53.5MB/s:11s
