cluster statistics show
Display cluster-wide statistics
The cluster statistics show
command displays the following information. Each item lists the current value and; if applicable, the change (delta) from the previous reported value.
CPU busy percentage
Average of CPU busy percentage (advanced privilege level only)
Total number of NFS and CIFS operations
Number of NFS operations
Number of CIFS operations
Number of cache operations (advanced privilege level only)
Total amount of network data received (advanced privilege level only)
Total amount of network data sent (advanced privilege level only)
Number of packets received (advanced privilege level only)
Number of packets sent (advanced privilege level only)
Busy percentage for the data network
Amount of data received on the data network
Amount of data sent on the data network
Busy percentage for the cluster network
Amount of data received on the cluster network
Amount of data sent on the cluster network
Amount of data read from disk
Amount of data written to disk
At the diagnostic privilege level, the command displays the following information:
CPU busy percentage
Total number of operations
Number of 7M Fcache operations
Number of SpinFS operations
Total amount of network traffic received
Total amount of network traffic sent
Percentage of data-network utilization
Amount of data-network traffic received
Amount of data-network traffic sent
Percentage of cluster-network utilization
Amount of cluster-network traffic received
Amount of cluster-network traffic sent
The following example displays cluster statistics:
cluster1::> cluster statistics show Counter Value Delta ------------- ------------- ------------- CPU Busy: 84% +27 Operations: Total: 951471448 7210/s:11s NFS: 12957951479 13759/s:11s CIFS: 342195460 230/s:11s Data Network: Busy: 0% - Received: 1.98TB 3.18MB/s:11s Sent: 6.20TB 903KB/s:11s Cluster Network: Busy: 0% - Received: 6.33TB 1.34MB/s:11s Sent: 6.24TB 3.54MB/s:11s Storage Disk: Read: 207TB 82.7MB/s:11s Write: 53.3TB 53.5MB/s:11s
