Command reference
vserver cifs users-and-groups local-user show
Display local users
The vserver cifs users-and-groups local-user show command displays local users and their attributes.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver
If this parameter is specified, the command displays information only about local users that match the specified Vserver name.
[-user-name <CIFS name>] - User Name
If this parameter is specified, the command displays information only about local users that match the specified user name.
[-full-name <TextNoCase>] - Full Name
If this parameter is specified, the command displays information only about local users that match the specified full name.
[-description <TextNoCase>] - Description
If this parameter is specified, the command displays information only about local users that match the specified description.
[-is-account-disabled {true|false}] - Is Account Disabled
If this parameter is specified, the command displays information only about local users that match the status specified.
The following example displays information about all local users.
cluster1::> vserver cifs users-and-groups local-user show
Vserver      User Name                   Full Name            Description
vs1          CIFS_SERVER\Administrator   James Raynor         Built-in administrator account
vs1          CIFS_SERVER\u1              Sarah Kerrigan
2 entries were displayed.
