vserver cifs users-and-groups local-user show
Display local users
The vserver cifs users-and-groups local-user show
command displays local users and their attributes.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver name>]
- Vserver-
If this parameter is specified, the command displays information only about local users that match the specified Vserver name.
[-user-name <CIFS name>]
- User Name-
If this parameter is specified, the command displays information only about local users that match the specified user name.
[-full-name <TextNoCase>]
- Full Name-
If this parameter is specified, the command displays information only about local users that match the specified full name.
[-description <TextNoCase>]
- Description-
If this parameter is specified, the command displays information only about local users that match the specified description.
[-is-account-disabled {true|false}]
- Is Account Disabled-
If this parameter is specified, the command displays information only about local users that match the status specified.
The following example displays information about all local users.
cluster1::> vserver cifs users-and-groups local-user show Vserver User Name Full Name Description ------------ --------------------------- -------------------- ------------- vs1 CIFS_SERVER\Administrator James Raynor Built-in administrator account vs1 CIFS_SERVER\u1 Sarah Kerrigan 2 entries were displayed.
