security dynamic-authorization rule show
Show dynamic authorization rules
The security dynamic-authorization rule show displays information about dynamic authorization rules, which includes both pre-defined as well as custom dynamic authorization rules.
[-fields <fieldname>,…] -
Selects the fields that you specify.
[-instance ]} -
Displays all the fields for the specified dynamic authorization rules.
[-vserver <vserver name>]- Vserver-
Selects the dynamic authorization rules that match this parameter value.
[-operation <Command or Command Directory>]- Command or Command Directory-
[-query <query>]- Query-
The example below displays information about all dynamic authorization rules whose operation matches the prefix security multi-admin-verify .
cluster1::*> security dynamic-authorization rule show -operation "security multi-admin-verify"* Vserver: cluster1 Operation Query ---------------------------------------- ----------------------------------- security multi-admin-verify security multi-admin-verify approval-group security multi-admin-verify approval-group replace security multi-admin-verify rule Vserver: vs1 Operation Query ---------------------------------------- ----------------------------------- security multi-admin-verify security multi-admin-verify approval-group security multi-admin-verify approval-group replace security multi-admin-verify rule 8 entries were displayed.
