Command reference
security dynamic-authorization rule show
Show dynamic authorization rules
The security dynamic-authorization rule show displays information about dynamic authorization rules, which includes both pre-defined as well as custom dynamic authorization rules.
{ [-fields <fieldname>,…​]
Selects the fields that you specify.
| [-instance ] }
Displays all the fields for the specified dynamic authorization rules.
[-vserver <vserver name>] - Vserver
Selects the dynamic authorization rules that match this parameter value.
[-operation <Command or Command Directory>] - Command or Command Directory
[-query <query>] - Query
The example below displays information about all dynamic authorization rules whose operation matches the prefix security multi-admin-verify .
cluster1::*> security dynamic-authorization rule show -operation "security multi-admin-verify"*
Vserver: cluster1
Operation                                                              Query
security multi-admin-verify approval-group
security multi-admin-verify approval-group replace
security multi-admin-verify rule
Vserver: vs1
Operation                                                              Query
8 entries were displayed.
