volume quota policy rule delete
Delete an existing quota rule
The volume quota policy rule delete command deletes a quota policy rule. You must enter the following information to delete a quota policy rule:
Vserver name
Quota policy name
Volume name
Quota target type
Target to which the rule applies
Qtree to which the rule applies
NOTE:
If the rule being deleted belongs to the quota policy that is currently assigned to the Vserver, enforcement of the rule on the volume must be terminated by performing a quota off and on or a quota resize operation using the "volume quota modify " command.
-vserver <vserver name>- Vserver-
This parameter specifies the Vserver containing the quota policy for which you are deleting a rule.
-policy-name <text>- Policy Name-
This parameter specifies the name of the quota policy in which you are deleting a rule.
-volume <volume name>- Volume Name-
This parameter specifies the name of the volume for which you are deleting a rule.
-type {tree|user|group}- Type-
This parameter specifies the quota target type for the rule.
-target <text>- Target-
This parameter specifies the target to which the quota policy rule applies.
-qtree <qtree name>- Qtree Name-
This parameter specifies the name of the qtree for which you are deleting a rule.
The following example deletes a quota policy rule on Vserver vs1 for the quota policy named quota_policy_1. This quota policy applies to the group named engr for the qtree named qtree1 on volume vol1.
cluster1::> volume quota policy rule delete -vserver vs1 -policy-name quota_policy_1 -volume vol1 -type group -target engr -qtree qtree1
