volume quota policy rule delete
Delete an existing quota rule
The volume quota policy rule delete
command deletes a quota policy rule. You must enter the following information to delete a quota policy rule:
Vserver name
Quota policy name
Volume name
Quota target type
Target to which the rule applies
Qtree to which the rule applies
If the rule being deleted belongs to the quota policy that is currently assigned to the Vserver, enforcement of the rule on the volume must be terminated by performing a quota off and on or a quota resize operation using the "volume quota modify " command. |
-vserver <vserver name>
- Vserver-
This parameter specifies the Vserver containing the quota policy for which you are deleting a rule.
-policy-name <text>
- Policy Name-
This parameter specifies the name of the quota policy in which you are deleting a rule.
-volume <volume name>
- Volume Name-
This parameter specifies the name of the volume for which you are deleting a rule.
-type {tree|user|group}
- Type-
This parameter specifies the quota target type for the rule.
-target <text>
- Target-
This parameter specifies the target to which the quota policy rule applies.
-qtree <qtree name>
- Qtree Name-
This parameter specifies the name of the qtree for which you are deleting a rule.
The following example deletes a quota policy rule on Vserver vs1 for the quota policy named quota_policy_1. This quota policy applies to the group named engr for the qtree named qtree1 on volume vol1.
cluster1::> volume quota policy rule delete -vserver vs1 -policy-name quota_policy_1 -volume vol1 -type group -target engr -qtree qtree1
