Command reference
security key-manager external aws show
Display AWS KMS configuration
This command displays the Amazon Web Service Key Management Service (AWSKMS) configuration for a given Vserver.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <Vserver Name>] - Vserver
If you specify this parameter, then the command displays only the AWSKMS configuration for the given Vserver.
[-region <text>] - AWS KMS Region
If you specify this parameter, then the command displays only the AWSKMS configuration with the given region.
[-key-id <text>] - AWS Key ID
If you specify this parameter, then the command displays only the AWSKMS configuration with the given key-id.
[-access-key-id <text>] - AWS Access Key ID
If you specify this parameter, then the command displays only the AWSKMS configuration with the given access key ID.
[-service <text>] - AWS Service Type
If you specify this parameter, then the command displays only the AWSKMS configurations with the given AWS service type.
[-default-domain <text>] - AWS KMS Default Domain
If you specify this parameter, then the command displays only the AWSKMS configurations with the given AWS KMS default domain.
[-state {available|not-responding|unknown}] - AWS KMS Cluster State
If you specify this parameter, then the command displays only the AWSKMS configurations with the given state. The state can be either available or unknown.
[-unavailable-nodes <text>] - Names of Unavailable Nodes
If you specify this parameter, then the command displays only the AWSKMS configurations with the given unavailable-nodes.
[-polling-period <integer>] - Polling period (in minutes)
If you specify this parameter, then the command displays only the AWSKMS configurations with the given polling period.
[-port <integer>] - AWS KMS Port
If you specify this parameter, then the command displays only the AWSKMS configurations with the given AWS KMS port.
[-verify {true|false}] - Verify the AWS KMS Host
If you specify this parameter, then the command displays only the AWSKMS configurations with the given value of the verify flag.
[-verify-host {true|false}] - Verify the AWS KMS Host's Hostname
If you specify this parameter, then the command displays only the AWSKMS configurations with the given value of the verify-host flag.
[-verify-ip {true|false}] - Verify the AWS KMS Host's IP
If you specify this parameter, then the command displays only the AWSKMS configurations with the given value of the verify-ip flag.
[-host <text>] - AWS KMS Host Name
If you specify this parameter, then the command displays only the AWSKMS configurations with the given AWS KMS host name.
[-encryption-context <text>] - Additional Layer of Authentication and Logging
If you specify this parameter, then the command displays only the AWSKMS configurations with the given value of the AWS encryption-context. The parameter should be in JSON format.
The following example lists all AWSKMS configurations.
cluster-1::>security key-manager external aws show
            Vserver: SAMPLE_VSERVER
             Region: SAMPLE_NA_REGION
Access Key Id                                State
SAMPLE_ACCESS_KEY_ID                         unknown
SAMPLE_ACCESS_KEY_ID_2                       unknown
Unavailable Nodes:                           node1
The following example lists the AWSKMS configurations that have the given encryption context of "{"team": "NVEsecurity"}".
cluster-1::>security key-manager external aws show -encryption-context {"team": "NVEsecurity"}
Access Key Id                                State
