security key-manager external aws show
Display AWS KMS configuration
This command displays the Amazon Web Service Key Management Service (AWSKMS) configuration for a given Vserver.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-vserver <Vserver Name>]- Vserver
If you specify this parameter, then the command displays only the AWSKMS configuration for the given Vserver.
- [-region <text>]- AWS KMS Region
If you specify this parameter, then the command displays only the AWSKMS configuration with the given region.
- [-key-id <text>]- AWS Key ID
If you specify this parameter, then the command displays only the AWSKMS configuration with the given key-id.
- [-access-key-id <text>]- AWS Access Key ID
If you specify this parameter, then the command displays only the AWSKMS configuration with the given access key ID.
- [-service <text>]- AWS Service Type
If you specify this parameter, then the command displays only the AWSKMS configurations with the given AWS service type.
- [-default-domain <text>]- AWS KMS Default Domain
If you specify this parameter, then the command displays only the AWSKMS configurations with the given AWS KMS default domain.
- [-state {available|not-responding|unknown}]- AWS KMS Cluster State
If you specify this parameter, then the command displays only the AWSKMS configurations with the given state. The state can be either available or unknown.
- [-unavailable-nodes <text>]- Names of Unavailable Nodes
If you specify this parameter, then the command displays only the AWSKMS configurations with the given unavailable-nodes.
- [-polling-period <integer>]- Polling period (in minutes)
If you specify this parameter, then the command displays only the AWSKMS configurations with the given polling period.
- [-port <integer>]- AWS KMS Port
If you specify this parameter, then the command displays only the AWSKMS configurations with the given AWS KMS port.
- [-verify {true|false}]- Verify the AWS KMS Host
If you specify this parameter, then the command displays only the AWSKMS configurations with the given value of the verify flag.
- [-verify-host {true|false}]- Verify the AWS KMS Host's Hostname
If you specify this parameter, then the command displays only the AWSKMS configurations with the given value of the verify-host flag.
- [-verify-ip {true|false}]- Verify the AWS KMS Host's IP
If you specify this parameter, then the command displays only the AWSKMS configurations with the given value of the verify-ip flag.
- [-host <text>]- AWS KMS Host Name
If you specify this parameter, then the command displays only the AWSKMS configurations with the given AWS KMS host name.
- [-encryption-context <text>]- Additional Layer of Authentication and Logging
If you specify this parameter, then the command displays only the AWSKMS configurations with the given value of the AWS encryption-context. The parameter should be in JSON format.
The following example lists all AWSKMS configurations.
cluster-1::>security key-manager external aws show
            Vserver: SAMPLE_VSERVER
             Region: SAMPLE_NA_REGION
Access Key Id                                State
SAMPLE_ACCESS_KEY_ID                         unknown
SAMPLE_ACCESS_KEY_ID_2                       unknown
Unavailable Nodes:                           node1
The following example lists the AWSKMS configurations that have the given encryption context of "{"team": "NVEsecurity"}".
cluster-1::>security key-manager external aws show -encryption-context {"team": "NVEsecurity"}
Access Key Id                                State
 PDFs
PDFs
