system switch ethernet show
Display the configuration for Ethernet switches (cluster and storage).
The system switch ethernet show command displays configuration details for cluster and storage Ethernet switches.
[-fields <fieldname>,…] -
Selects the fields that have the specified name.
[-banner ] -
Displays the following information about a switch:
Device Name
Banner seen when accessing the switch through SSH.
[-snmp-config ] -
Device Name
SNMPv2c Community String or SNMPv3 Username
SNMP Version
[-status ] -
Displays the following status information about a switch:
Is Discovered
Model Number
Switch Network
Software Version
Reason For Not Monitoring
Source Of Switch Version
Is Monitored ?
[-instance ]} -
Selects detailed information for all the switches.
[-device <text>]- Device Name-
Selects the switches that match the specified device name.
[-address <IP Address>]- IP Address-
Selects the switches that match the specified IP address.
[-snmp-version {SNMPv1|SNMPv2c|SNMPv3}]- SNMP Version-
Selects the switches that match the specified SNMP version.
[-is-discovered {true|false}]- Is Discovered-
Selects the switches that match the specified discovery setting.
[-community-or-username <text>]- SNMPv2c Community String or SNMPv3 Username-
Selects the switches that match the specified SNMPv2c community string or SNMPv3 username.
[-model {OTHER|NX3132V|NX3232C}]- Model Number-
Selects the switches that match the specified model number.
[-type {cluster-network|storage-network}]- Switch Network-
Selects the switches that match the specified switch type.
[-sw-version <text>]- Software Version-
Selects the switches that match the specified software version.
[-reason <text>]- Reason For Not Monitoring-
Selects the switches that match the specified reason.
[-version-source <text>]- Source Of Switch Version-
Selects the switches that match the specified version source (for example, SNMP, CDP, ISDP, or LLDP).
[-is-monitoring-enabled-admin {true|false}]- Enable Switch Monitoring-
Selects the switches that match the specified admin monitoring status.
[-is-monitoring-enabled-operational {true|false}]- Is Monitored ?-
Selects the switches that match the specified operational monitoring status.
[-serial-number <text>]- Serial Number of the Device-
Selects the switches that match the specified serial number.
[-device-banner <text>]- Device Banner-
[-rcf-version <text>]- Reference Config File Version-
Selects the switches that match the specified reference configuration file version.
[-role <text>]- Configured Role-
Selects the switches that match the specified role or combined role (different roles can be combined using '+'):
cluster
multicluster
storage
multistorage
metrocluster
cluster1::> system switch ethernet show
Switch Type Address Model
SwitchA cluster-network 1.2.3.4 N9K-C9336C-FX2
Serial Number: FFF123456V1
Is Monitored: true
Reason: None
Software Version: Cisco Nexus Operating System (NX-OS) Software, Version
10.3(4a)
Version Source: CDP/ISDP
SwitchB cluster-network 2.3.4.5 N9K-C9336C-FX2
Serial Number: FEE234567V2
Is Monitored: true
Reason: None
10.3(4a)
The example above displays the configuration of all Ethernet switches (cluster and storage).
cluster1::> system switch ethernet show -snmp-config
SNMPv2c Community
Switch or SNMPv3 Username SNMP Version
SwitchA public SNMPv2c
The example above displays the SNMPv2c community string or SNMPv3 username and SNMP version for all Ethernet switches (cluster and storage).
cluster1::> system switch ethernet show -banner Device: SwitchA --------------- ****************************************************************************** * * NetApp Reference Configuration File (RCF) * Switch : SwitchModel * Filename : SwitchType-RCF-v1.8-Cluster * Release Date : Apr-04-2022 * Version : v1.8 * ******************************************************************************
The example above shows the SSH banner for all the Ethernet switches (cluster and storage).
