system switch ethernet show
Display the configuration for Ethernet switches (cluster, management and storage).
The system switch ethernet show command displays configuration details for the monitored Ethernet switches (cluster, management and storage).
[-fields <fieldname>,…] -
Selects the fields that have the specified name.
[-snmp-config ] -
Displays the following information about a switch:
Device Name
SNMPv2c Community String or SNMPv3 Username
SNMP Version
[-status ] -
Displays the following status information about a switch:
Is Discovered
Model Number
Switch Network
Software Version
Reason For Not Monitoring
Source Of Switch Version
Is Monitored ?
[-instance ]} -
Selects detailed information for all the switches.
 [-device <text>]- Device Name-
Selects the switches that match the specified device name.
 [-address <IP Address>]- IP Address-
Selects the switches that match the specified IP address.
 [-snmp-version {SNMPv1|SNMPv2c|SNMPv3}]- SNMP Version-
Selects the switches that match the specified SNMP version.
 [-is-discovered {true|false}]- Is Discovered-
Selects the switches that match the specified discovery setting.
 [-community <text>]- DEPRECATED-Community String or SNMPv3 Username-
This parameter is deprecated and may be removed in a future release of ONTAP. Use -community-or-usernameinstead.Selects the switches that match the specified SNMPv2c community string or SNMPv3 username.
 [-community-or-username <text>]- Community String or SNMPv3 Username-
 [-model {NX5010|NX5020|CAT2960|OTHER|NX5596|CN1610|CN1601|NX3132|NX5548|NX3132V|OT9332|NX3132XL|NX3232C}]- Model Number-
Selects the switches that match the specified model number.
 [-type {cluster-network|management-network|storage-network}]- Switch Network-
Selects the switches that match the specified switch type.
 [-sw-version <text>]- Software Version-
Selects the switches that match the specified software version.
 [-reason <text>]- Reason For Not Monitoring-
Selects the switches that match the specified reason.
 [-version-source <text>]- Source Of Switch Version-
Selects the switches that match the specified version source (for example, from SNMP, CDP or ISDP).
 [-is-monitoring-enabled-operational {true|false}]- Is Monitored ?-
Selects the switches that match the specifed operational monitoring status.
 [-serial-number <text>]- Serial Number of the Device-
Selects the switches that match the specified serial number.
cluster1::> system switch ethernet show
  Switch                      Type               Address          Model
  cn1610-143--234             cluster-network    10.238.143.234   CN1610
       Serial Number: 20211200007
        Is Monitored: true
              Reason:
    Software Version: 1.1.0.1
      Version Source: ISDP
cn1601--143-230             management-network 10.238.143.230   CN1601
       Serial Number: 20210200019
        Is Monitored: false
              Reason: Monitoring Disabled by Default
cn1601--143-232             management-network 10.238.143.232   CN1601
       Serial Number: 20210200017
        Is Monitored: false
cn1610-143--231             cluster-network    10.238.143.231   CN1610
       Serial Number: 20211200002
        Is Monitored: true
              Reason:
The example above displays the configuration of all Ethernet switches (cluster, management and storage).
cluster1::> system switch ethernet show -snmp-config
                SNMPv2c Community
  Switch        or SNMPv3 Username    SNMP Version
  SwitchA       public                SNMPv2c
The example above displays the SNMPv2c community string or SNMPv3 username and SNMP version for all Ethernet switches (cluster, management and storage).
