Command reference
system switch ethernet show
Display the configuration for Ethernet switches (cluster and storage).
The system switch ethernet show command displays configuration details for cluster and storage Ethernet switches.
{ [-fields <fieldname>,…​]
Selects the fields that have the specified name.
| [-banner ]
Displays the following information about a switch:
  • Device Name
  • Banner seen when accessing the switch through SSH.
| [-snmp-config ]
  • Device Name
  • SNMPv2c Community String or SNMPv3 Username
  • SNMP Version
| [-status ]
Displays the following status information about a switch:
  • Is Discovered
  • Model Number
  • Switch Network
  • Software Version
  • Reason For Not Monitoring
  • Source Of Switch Version
  • Is Monitored ?
| [-instance ] }
Selects detailed information for all the switches.
[-device <text>] - Device Name
Selects the switches that match the specified device name.
[-address <IP Address>] - IP Address
Selects the switches that match the specified IP address.
[-snmp-version {SNMPv1|SNMPv2c|SNMPv3}] - SNMP Version
Selects the switches that match the specified SNMP version.
[-is-discovered {true|false}] - Is Discovered
Selects the switches that match the specified discovery setting.
[-community-or-username <text>] - SNMPv2c Community String or SNMPv3 Username
Selects the switches that match the specified SNMPv2c community string or SNMPv3 username.
[-model {OTHER|NX3132V|NX3232C}] - Model Number
Selects the switches that match the specified model number.
[-type {cluster-network|storage-network}] - Switch Network
Selects the switches that match the specified switch type.
[-sw-version <text>] - Software Version
Selects the switches that match the specified software version.
[-reason <text>] - Reason For Not Monitoring
Selects the switches that match the specified reason.
[-version-source <text>] - Source Of Switch Version
Selects the switches that match the specified version source (for example, SNMP, CDP, ISDP, or LLDP).
[-is-monitoring-enabled-admin {true|false}] - Enable Switch Monitoring
Selects the switches that match the specified admin monitoring status.
[-is-monitoring-enabled-operational {true|false}] - Is Monitored ?
Selects the switches that match the specified operational monitoring status.
[-serial-number <text>] - Serial Number of the Device
Selects the switches that match the specified serial number.
[-device-banner <text>] - Device Banner
[-rcf-version <text>] - Reference Config File Version
Selects the switches that match the specified reference configuration file version.
[-role <text>] - Configured Role
Selects the switches that match the specified role or combined role (different roles can be combined using '+'):
  • cluster
  • multicluster
  • storage
  • multistorage
  • metrocluster
cluster1::> system switch ethernet show
  Switch                      Type               Address          Model
  SwitchA                     cluster-network    1.2.3.4          N9K-C9336C-FX2
     Serial Number: FFF123456V1
      Is Monitored: true
            Reason: None
  Software Version: Cisco Nexus Operating System (NX-OS) Software, Version
                    10.3(4a)
    Version Source: CDP/ISDP
SwitchB                     cluster-network    2.3.4.5          N9K-C9336C-FX2
     Serial Number: FEE234567V2
      Is Monitored: true
            Reason: None
                    10.3(4a)
The example above displays the configuration of all Ethernet switches (cluster and storage).
cluster1::> system switch ethernet show -snmp-config
                SNMPv2c Community
  Switch        or SNMPv3 Username    SNMP Version
  SwitchA       public                SNMPv2c
The example above displays the SNMPv2c community string or SNMPv3 username and SNMP version for all Ethernet switches (cluster and storage).
cluster1::> system switch ethernet show -banner
  Device: SwitchA
  * NetApp Reference Configuration File (RCF)
  * Switch       : SwitchModel
  * Filename     : SwitchType-RCF-v1.8-Cluster
  * Release Date : Apr-04-2022
  * Version      : v1.8
The example above shows the SSH banner for all the Ethernet switches (cluster and storage).
