lun mapping remove-reporting-nodes
Remove Reporting Nodes
This command is used after a data mobility event to remove reporting nodes that are no longer required for optimized access from the specified LUN mapping.
For more information on managing reporting nodes in response to data mobility events, see the ONTAP SAN Administration Guide.
-vserver <Vserver Name>- Vserver Name-
Specifies the name of the Vserver containing the LUN.
-path <path>- LUN Path -
Specifies the path of the LUN. Examples of correct LUN paths are:
/vol/vol1/lun1and/vol/vol1/qtree1/lun1 - |
-volume <volume name>- Volume Name -
Specifies the volume that contains the LUN.
[-qtree <qtree name>]- Qtree Name-
Specifies the qtree that contains the LUN.
-lun <text>- LUN Name }-
Specifies the LUN name.
-g, -igroup <text>- Igroup Name-
Specifies the igroup the LUN is mapped to.
-remote-nodes <true>- Remove Remote Nodes for LUN Location-
If specified, remove all nodes other than the LUN's owner and HA partner from the LUN mapping's reporting nodes.
cluster1::> lun mapping remove-reporting-nodes -vserver vs1 -path /vol/vol1/lun1 -igroup ig1
Remove excess remote nodes from the LUN mapping of /vol/vol1/lun1 to igroup ig1 .
