Command reference
network fcp zone show
Display the active zone set information
Displays the active zone set information.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
Use this parameter to select the active zone set information for adapters that located on the node name that you specify.
[-adapter <text>] - Adapter
Use this parameter to select the active zone set information for the specified adapter.
[-zoneset-name <text>] - Zoneset Name
Use this parameter to select the active zone set information for the specified zone set name.
[-zone-name <text>] - Zone Name
Use this parameter to select the active zone set information for the specified zone name.
[-type-name <text>] - Type Name
Use this parameter to select the active zone set information with the specified symbolic type.
[-type <integer>] - Type
Use this parameter to select the active zone set information with the specified port type.
[-port-id <Hex Integer>] - Member Port Id
Use this parameter to select the active zone set information with the specified member port id.
[-domain-id <integer>] - Member Domain Id
Use this parameter to select the active zone set information with the specified member domain id.
[-port <integer>] - Member Port
Use this parameter to select the active zone set information with the specified member port.
[-wwn <text>] - Member WWN
Use this parameter to select the active zone set information with the specified member WWN.
[-zone-count <integer>] - Zone Count
Use this parameter to select the active zone set information with the specified number of zones.
[-zone-member-count <integer>] - Zone Member Count
Use this parameter to select the active zone set information with the specified number of zone members in a zone.
[-contents <text>] - Member Contents
Use this parameter to select the active zone set information using any type.
cluster1::> network fcp adapter zone show
                                          Member
                       Zone Name          Type                WWN
Active Zone Set on adapter 0c
   Zone Set Name: zoneset_name
                       zone_name_1        Port ID             -
                       zone_name_2        Domain ID/Port      -
                       zone_name_3        Fabric Port Name    00:00:00:00:00:00:00:00
                       zone_name_3        Fabric Port Name    01:00:00:00:00:00:00:00
                       zone_name_3        Fabric Port Name    02:00:00:00:00:00:00:00
9 entries were displayed.
The example above displays information regarding active zone set information for the cluster.
