system services web node show
Display the status of the web servers at the node level
This command displays operational configuration for the web server processes on the nodes in the cluster. This output is aggregated to produce the content for the system services web show command.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
Selects the nodes that match this parameter value. Identifies the node where the web server process is being executed.
[-external {true|false}]- External Web Services-
Selects the nodes that match this parameter value. Defines whether remote clients can access the HTTP or HTTPS service content. Along with the
system services firewallcommand configuration, this parameter controls the visibility for client connections. The default value for this parameter after installation istrue, which exports web protocols for remote access. [-http-port <integer>]- HTTP Port-
Selects the nodes that match this parameter value. Defines the HTTP port for the node-level web services.
[-https-port <integer>]- HTTPS Port-
Selects the nodes that match this parameter value. Defines the encrypted HTTP (HTTPS) port for the node-level web services.
[-http-enabled {true|false}]- HTTP Enabled-
Selects the nodes that match this parameter value. Defines whether HTTP is enabled.
[-per-address-limit <integer>]- Per Address Limit (privilege: advanced)-
Selects the nodes that match this parameter value. Limits the number of connections that can be processed concurrently from the same remote address. If more connections are accepted, those in excess of the limit are delayed and processed after the number of connections being processed drops below the limit.
[-status {offline|partial|mixed|online|unclustered}]- Protocol Status-
Selects the nodes that match this parameter value. Describes the operational state of node-level web services. This parameter does not reflect whether protocols are externally visible, but whether the server processes are running correctly. The following are the possible values that describe the service availability:
online, indicates that web services are working correctly.
offline, indicates that web services are unavailable due to an error condition.
unclustered, indicates that the current node is not part of an active cluster.
[-total-hits <integer>]- Total HTTP Requests-
Selects the nodes that match this parameter value. Indicates the total number of requests serviced by the web server.
[-total-bytes <integer>]- Total Bytes Served-
Selects the nodes that match this parameter value. Indicates the total number of bytes returned by the web server.
[-lif-service-policy-enforced {true|false}]- Enforce Network Interface Service-Policy-
Selects the nodes that match this parameter value. Defines whether network interface service-policy is enforced.
The following example displays the status of web servers for nodes in the cluster.
cluster1::system services web node> show
HTTP HTTP HTTPS Total Total
Node External enabled Port Port Status HTTP Requests Bytes Served
node1 true true 80 443 online 5 1362
node2 true true 80 443 online 5 1362
2 entries were displayed.
