storage aggregate delete
Delete an aggregate
The storage aggregate delete command deletes a storage aggregate. The command fails if there are volumes present on the aggregate. If the aggregate has an object store attached to it, then in addition to deleting the aggregate the command deletes the objects in the object store as well. No changes are made to the object store configuration as part of this command.
-aggregate <aggregate name>- Aggregate-
This parameter specifies the aggregate that is to be deleted.
[-preserve-config-data <true>]- Delete Physical Aggregate but Preserve Configuration Data (privilege: advanced)-
Deletes the physical aggregate, but preserves the aggregate configuration data. The aggregate must not have any disks associated with it. If the parameter
-preserve-config-datais specified without a value, the default value istrue; if this parameter is not specified, the default value isfalse.
The following example deletes an aggregate named aggr1:
cluster1::> storage aggregate delete -aggregate aggr1
