Command reference
volume efficiency prepare-to-downgrade
Identify any incompatible volumes or Snapshot copies before downgrade
The volume efficiency prepare-to-downgrade command updates efficiency configurations and metadata to be compatible with prior releases as specified. This command also disables the use of incompatible efficiency features. This command is not supported on FlexGroup volumes.
[-disable-feature-set <downgrade version>] - Data ONTAP Version (privilege: advanced)
This parameter specifies the ONTAP version that introduced new volume efficiency feature set.
The following example disables the features introduced in ONTAP 8.3.1
cluster1::*> volume efficiency prepare-to-downgrade -disable-feature-set 8.3.1
The following example disables the features introduced in ONTAP 9.6.0.
cluster1::*> volume efficiency prepare-to-downgrade -disable-feature-set 9.6.0
The following example ignores offline volumes while disabling the features introduced in ONTAP 9.6.0 .
cluster1::*> volume efficiency prepare-to-downgrade -disable-feature-set 9.6.0 -skip-offline-volumes true
The following example ignores offline volumes while disabling the features introduced in ONTAP 8.3.1 .
cluster1::*> volume efficiency prepare-to-downgrade -disable-feature-set 8.3.1 -skip-offline-volumes true
