vserver migrate show
Display status of migrating Vservers
This command displays information about the migrating vserver.
[-fields <fieldname>,…] -
If you specify the
[-migrate-status-details ] -
If this parameter is specified, the command displays the following information about Vserver migrate operation.
Vserver
Migrate status
Status details
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver Name-
Name of the Vserver which is migrating.
[-vserver-uuid <UUID>]- Vserver UUID-
If this parameter is specified, the command displays Vserver migrate information that matches the specified Vserver UUID.
[-destination-cluster <Cluster name>]- Destination Cluster Name-
If this parameter is specified, the command displays Vserver migrate information that matches the specified destination cluster.
[-source-cluster <Cluster name>]- Source Cluster Name-
If this parameter is specified, the command displays Vserver migrate information that matches the specified source cluster.
[-migrate-status {precheck-started|transferring|ready-for-cutover|cutover-triggered|cutover-started|cutover-complete|migrate-paused|migrate-complete|migrate-complete-with-warnings|migrate-failed|cleanup|cleanup-failed|manual-cleanup|destination-cleaned-up|migrate-pausing|cleanup-pausing|post-cutover|post-cutover-failed|ready-for-source-cleanup|setup-configuration|setup-configuration-failed|migrate-pause-failed|migrate-aborting|migrate-abort-failed|migrate-aborted}]- Vserver migrate status-
If this parameter is specified, the command displays Vserver migrate information that matches the specified Vserver migrate status.
[-start-time <MM/DD/YYYY HH:MM:SS>]- Migrate start time-
If this parameter is specified, the command displays Vserver migrate information that matches the specified Vserver migrate start time.
[-end-time <MM/DD/YYYY HH:MM:SS>]- Migrate operation finish time-
If this parameter is specified, the command displays Vserver migrate information that matches the specified Vserver migrate end time.
[-last-pause-time <MM/DD/YYYY HH:MM:SS>]- Last migrate pause time-
If this parameter is specified, the command displays Vserver migrate information that matches the specified Vserver migrate last paused time.
[-last-resume-time <MM/DD/YYYY HH:MM:SS>]- Last migrate resume time-
If this parameter is specified, the command displays Vserver migrate information that matches the specified Vserver migrate last resume time.
[-last-restart-time <MM/DD/YYYY HH:MM:SS>]- Last migrate restart time-
If this parameter is specified, the command displays Vserver migrate information that matches the specified Vserver migrate last rollback time.
[-cutover-precommit-start-time <MM/DD/YYYY HH:MM:SS>]- Cutover precommit start time-
If this parameter is specified, the command displays Vserver migrate information that matches the specified Vserver migrate cutover trigger time.
[-cutover-commit-start-time <MM/DD/YYYY HH:MM:SS>]- Cutover commit start time-
If this parameter is specified, the command displays Vserver migrate information that matches the specified Vserver migrate cutover start time.
[-cutover-complete-time <MM/DD/YYYY HH:MM:SS>]- Cutover complete time-
If this parameter is specified, the command displays Vserver migrate information that matches the specified Vserver migrate cutover completion time.
[-restart-count <integer>]- Restart Count-
If this parameter is specified, the command displays Vserver migrate information that matches the specified rollback count.
[-status-details <text>,…]- Errors and Warnings During Migrate-
If this parameter is specified, the command displays Vserver migrate information that matches the specified Vserver migrate status details.
[-ipspace <IPspace>]- Destination cluster IPspace Name for vserver-
If this parameter is specified, the command displays Vserver migrate information that matches the specified ipspace.
[-aggr-list <aggregate name>,…]- Aggregate list for creating the volumes-
If this parameter is specified, the command displays Vserver migrate information that matches the specified aggregate list that are assigned for Vserver to use.
[-migrate-vserver-type {migrate-source|migrate-destination}]- Identify if the Vserver is migrate source or destination-
If this parameter is specified, the command displays Vserver migrate information that matches the specified Vserver migrate type.
[-owning-node <nodename>]- Name of node on which migrate is orchestrated-
If this parameter is specified, the command displays Vserver migrate information that matches the specified node that owns Vserver migrate.
[-stream-uuid <UUID>]- Stream Uuid-
If this parameter is specified, the command displays Vserver migrate information that matches the specified stream UUID.
[-is-past-point-of-no-return {true|false}]- Indicate point of no return for migrate-
If this parameter is specified, the command displays Vserver migrate information that matches the specified past point of no return flag.
[-last-failed-migrate-status {precheck-started|transferring|ready-for-cutover|cutover-triggered|cutover-started|cutover-complete|migrate-paused|migrate-complete|migrate-complete-with-warnings|migrate-failed|cleanup|cleanup-failed|manual-cleanup|destination-cleaned-up|migrate-pausing|cleanup-pausing|post-cutover|post-cutover-failed|ready-for-source-cleanup|setup-configuration|setup-configuration-failed|migrate-pause-failed|migrate-aborting|migrate-abort-failed|migrate-aborted}]- Migrate status when the migrate aborted or failed-
If this parameter is specified, the command displays Vserver migrate information that matches the specified last failed Vserver migrate status.
[-current-migrate-operation {none|start|resume|pause|cleanup|cutover|abort}]- Current Migrate operation-
If this parameter is specified, the command displays Vserver migrate information that matches the specified current Vserver migrate operation.
[-last-migrate-operation {none|start|resume|pause|cleanup|cutover|abort}]- Last Migrate operation-
If this parameter is specified, the command displays Vserver migrate information that matches the specified last Vserver migrate operation.
[-local-vserver-id <integer>]- Vserver ID-
If this parameter is specified, the command displays Vserver migrate information that matches the specified local Vserver ID.
[-group-id <integer>]- Group ID-
If this parameter is specified, the command displays Vserver migrate information that matches the specified group ID.
[-partner-vserver-id <integer>]- Partner Vserver ID-
If this parameter is specified, the command displays Vserver migrate information that matches the specified Vserver ID of a partner node.
[-partner-group-id <integer>]- Partner group ID-
If this parameter is specified, the command displays Vserver migrate information that matches the specified group ID of a partner node.
[-auto-cutover {true|false}]- Automatic cutover-
If this parameter is specified, the command displays Vserver migrate information that matches the specified auto cutover flag.
[-migration-uuid <UUID>]- Migration UUID-
If this parameter is specified, the command displays Vserver migrate information that matches the specified migration UUID.
[-migration-failures <SmdbError>,…]- List of migration failures-
If this parameter is specified, the command displays Vserver migrate information that matches the specified migration failures.
[-client-outage-window <integer>]- Window duration during cutover when clients are not served-
If this parameter is specified, the command displays Vserver migrate information that matches the specified client outage window.
[-auto-source-cleanup {true|false}]- Automatic source cleanup (privilege: advanced)-
If this parameter is specified, the command displays Vserver migrate information that matches the specified auto source cleanup flag.
[-throttle <throttleType>]- Throttle for Migrate Transfers(Kbs)-
If this parameter is specified, the command displays Vserver migrate information that matches the specified throttle value.
[-post-ponr-retry-count <integer>]- Number of times migrate retried operations post-PONR-
If this parameter is specified, the command displays Vserver migrate information that matches the specified post point of no return retry count.
[-last-post-ponr-retry-time <MM/DD/YYYY HH:MM:SS>]- Last post-PONR retry time-
If this parameter is specified, the command displays Vserver migrate information that matches the specified last post point of no return retry time.
cluster1::> vserver migrate show -vserver test
