vserver migrate show
Display status of migrating Vservers
This command displays information about the migrating vserver.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-migrate-status-details ](privilege: advanced)
If this parameter is specified, the command displays the following information about Vserver migrate operation. -
Vserver
Migrate status
Status details
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-vserver <vserver name>]- Vserver Name (privilege: advanced)
Name of the Vserver which is migrating.
- [-vserver-uuid <UUID>]- Vserver UUID (privilege: advanced)
If this parameter is specified, the command displays Vserver migrate information that matches the specified Vserver UUID.
- [-transaction-id <integer>]- Transaction Id (privilege: advanced)
If this parameter is specified, the command displays Vserver migrate information that matches the specified transaction-id. A transaction-id is a 64 bit integer which identifies each Vserver migrate operation uniquely
- [-destination-cluster <Cluster name>]- Destination Cluster Name (privilege: advanced)
If this parameter is specified, the command displays Vserver migrate information that matches the specified destination cluster.
- [-source-cluster <Cluster name>]- Source Cluster Name (privilege: advanced)
If this parameter is specified, the command displays Vserver migrate information that matches the specified source cluster.
- [-migrate-status {precheck-started|transferring|ready-for-cutover|cutover-triggerred|cutover-started|cutover-complete|migrate-paused|migrate-complete|migrate-complete-with-warnings|migrate-failed|post-cutover-cleanup|cleanup-failed|manual-cleanup|destination-cleaned-up|migrate-pausing|cleanup-pausing}]- Vserver migrate status (privilege: advanced)
If this parameter is specified, the command displays Vserver migrate information that matches the specified Vserver migrate status.
- [-start-time <MM/DD/YYYY HH:MM:SS>]- Migrate start time (privilege: advanced)
If this parameter is specified, the command displays Vserver migrate information that matches the specified Vserver migrate start time.
- [-completion-time <MM/DD/YYYY HH:MM:SS>]- Migrate operation finish time (privilege: advanced)
If this parameter is specified, the command displays Vserver migrate information that matches the specified Vserver migrate completion time.
- [-last-pause-time <MM/DD/YYYY HH:MM:SS>]- Last migrate pause time (privilege: advanced)
If this parameter is specified, the command displays Vserver migrate information that matches the specified Vserver migrate last paused time.
- [-last-resume-time <MM/DD/YYYY HH:MM:SS>]- Last migrate resume time (privilege: advanced)
If this parameter is specified, the command displays Vserver migrate information that matches the specified Vserver migrate last resume time.
- [-last-rollback-time <MM/DD/YYYY HH:MM:SS>]- Last migrate rollback time (privilege: advanced)
If this parameter is specified, the command displays Vserver migrate information that matches the specified Vserver migrate last rollback time.
- [-cutover-trigger-time <MM/DD/YYYY HH:MM:SS>]- Cutover trigger time (privilege: advanced)
If this parameter is specified, the command displays Vserver migrate information that matches the specified Vserver migrate cutover trigger time.
- [-cutover-start-time <MM/DD/YYYY HH:MM:SS>]- Cutover start time (privilege: advanced)
If this parameter is specified, the command displays Vserver migrate information that matches the specified Vserver migrate cutover start time.
- [-cutover-complete-time <MM/DD/YYYY HH:MM:SS>]- Cutover complete time (privilege: advanced)
If this parameter is specified, the command displays Vserver migrate information that matches the specified Vserver migrate cutover completion time.
- [-rollback-count <integer>]- Rollback Count (privilege: advanced)
If this parameter is specified, the command displays Vserver migrate information that matches the specified rollback count.
- [-status-details <text>,…]- Errors and Warnings During Migrate (privilege: advanced)
If this parameter is specified, the command displays Vserver migrate information that matches the specified Vserver migrate status details.
- [-cutover-window <integer>]- cutover duration(seconds) (privilege: advanced)
If this parameter is specified, the command displays Vserver migrate information that matches the specified Vserver migrate cutover window.
- [-ipspace <IPspace>]- Destination cluster IPspace Name for vserver (privilege: advanced)
If this parameter is specified, the command displays Vserver migrate information that matches the specified ipspace.
- [-force {true|false}]- Force cutover until completion (privilege: advanced)
If force is set to "true", the command will only display Vserver migrate operation information about Vservers where the value of force is set to "true". If set to "false", the command will only display Vserver migrate operation information where force is set to "false".
- [-aggr-list <aggregate name>,…]- Aggregate list for creating the volumes (privilege: advanced)
If this parameter is specified, the command displays Vserver migrate information that matches the specified aggregate list that are assigned for Vserver to use.
- [-migrate-vserver-type {migrate-source|migrate-destination}]- Identify if the Vserver is migrate source or destination (privilege: advanced)
If this parameter is specified, the command displays Vserver migrate information that matches the specified Vserver migrate type.
- [-is-past-point-of-no-return {true|false}]- Indicate point of no return for migrate (privilege: advanced)
If this parameter is specified, the command displays Vserver migrate information that matches the specified past point of no return flag.
- [-current-migrate-operation {none|start|resume|pause|cleanup|cutover}]- Current Migrate operation (privilege: advanced)
If this parameter is specified, the command displays Vserver migrate information that matches the specified current Vserver migrate operation.
- [-last-migrate-operation {none|start|resume|pause|cleanup|cutover}]- Last Migrate operation (privilege: advanced)
If this parameter is specified, the command displays Vserver migrate information that matches the specified last Vserver migrate operation.
- [-local-vserver-id <integer>]- Vserver ID (privilege: advanced)
If this parameter is specified, the command displays Vserver migrate information that matches the specified local vserver id.
- [-group-id <integer>]- Group ID (privilege: advanced)
If this parameter is specified, the command displays Vserver migrate information that matches the specified group id.
- [-partner-vserver-id <integer>]- Partner Vserver ID (privilege: advanced)
If this parameter is specified, the command displays Vserver migrate information that matches the specified partner vserver id.
- [-partner-group-id <integer>]- Partner group ID (privilege: advanced)
If this parameter is specified, the command displays Vserver migrate information that matches the specified partner group id.
- [-auto-cutover {true|false}]- Automatic cutover (privilege: advanced)
If this parameter is specified, the command displays Vserver migrate information that matches the specified auto cutover flag.
- [-skip-performance-check {true|false}]- Skip checking iops requirement of volume on destination aggregates (privilege: advanced)
If this parameter is specified, the command displays Vserver migrate information that matches the specified skip performance flag.
- [-cutover-ready-max-transfer-time-limit <integer>]- Transfer duration for marking ready for cutover (seconds) (privilege: advanced)
If this parameter is specified, the command displays Vserver migrate information that matches the specified time required to mark cutover ready.
cluster1::> vserver migrate show -vserver test
 PDFs
PDFs
